[ANSYS Meshing] 3D flat plate meshing with ICEM CFD
Old   January 16, 2014, 23:55
Default 3D flat plate meshing with ICEM CFD
Jun Milan
Jun_Milan is on a distinguished road
Hello everyone,
I'm very new to the subject of meshing ... I need to mesh a 3D flat plate in ICEM CFD to do some simulations for a university project !
A friend helped me with the meshing of a 2D plate. After that, I think I must extrude the geometry to 3D in the z direction and then convert my 2D mesh to 3D. I searched on the net but I didn't find any interesting article or tutorial about this.
Can anyone help me please?
If anyone know an article or a website where it is explained step by step how to mesh a 3D flat plate, it will be very helpful for me.
Thank you very much,
Jun_Milan
Jun_Milan is offline   Reply With Quote
Old   January 17, 2014, 07:47
kad
kad will become famous soon enoughkad will become famous soon enough
If your 2D mesh is fine you can extrude it in z-direction. You do not need to extrude the geometry. Mesh extrusion is part of the method I have talked about in this thread http://www.cfd-online.com/Forums/ans...787-prism.html. You only need to define one additional extrusion curve for this. Also take a look at the ICEM help.
kad is offline   Reply With Quote
Old   January 18, 2014, 10:07
Jun Milan
Hello Kad,
I'm having some problems following your method in the prism thread ... I don't know from where to start because my geometry is different from that of the post ...
I have a 2D flat plate given in the xy plane. Its length in the x direction is 0.03 m and contains 51 nodes; while in the y direction, its 0.02 m with 111 nodes. Precisely, I would like to extrude the mesh in the z direction to have 0.01 m length and 21 nodes defined.
Jun_Milan
Old   January 18, 2014, 12:11
kad
All you have to do is one extrude. The function is pretty self explanatory and is well documented in the manual.
For a fixed spacing in z-direction I would use extrude by vector. Otherwise you can create a curve with direction (0 0 1) and length 0.01. Apply mesh curve on it and you can extrude the mesh by curve. There is no need to extrude the geometry, you do not even have to load it at all.
Finally you have to create parts for the mesh boundaries e.g. inlet, wall, ... and put the corresponding mesh in them. Also run check mesh because the extrusion can create duplicate elements.
Btw. there is also a way to extrude the blocking itself, but I think you have to change geometry for this. It is used in this tutorial: http://www.youtube.com/watch?v=KabKFrJK3fM .
Old   January 20, 2014, 16:25
Jun Milan
Thank you Kad. The method of extruding directly the mesh worked well.
And this is a good article I've found it on the net, where they show us step by step how to mesh a 3D duct (or flat plate) ...
http://home.cc.umanitoba.ca/~engsjo/...duct-v1p01.pdf
Jun_Milan
Flat plate analysis in cfx hamed.majeed CFX 14 February 4, 2015 08:07
[ANSYS Meshing] double pipe heat exchanger meshing in ICEM CFD chitra ANSYS Meshing & Geometry 0 April 13, 2013 09:36
[ANSYS Meshing] Meshing for flat plate immersed solid hamed.majeed ANSYS Meshing & Geometry 0 July 10, 2012 14:32
[ICEM] Helicopter meshing tutorial - ICEM CFD Far ANSYS Meshing & Geometry 0 May 20, 2012 12:10
import ICEM CFD meshing into ansysworbench thhch ANSYS 1 December 8, 2010 02:11
