[ICEM] Problem in generating O-Grid
Old   January 15, 2014, 17:45
Default Problem in generating O-Grid
GeorgeL is on a distinguished road
I am fairly new to ICEM and I am trying to generate a mesh for a rectangular geometry with a tube going through. I generated a surface block and applied O-grid block on the tube surface, then proceeded to do a 2D-3D Sweep. From the attachment, it is generating an octagonal mesh instead of a circular one at the end of the tube. What do I need to do to fix this?
Thanks
George
Last edited by GeorgeL; January 15, 2014 at 18:02. Reason: Made the problem more clear
GeorgeL is offline   Reply With Quote
Old   January 16, 2014, 01:00
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
you are not associating edge to curves
Far is offline   Reply With Quote
Old   January 16, 2014, 10:48
Thanks Far, I'll check my associations!
Old   January 16, 2014, 11:07
This did it, Thanks!
Although I thought I did do the associations. It was interesting when I went back to the ICEM file where I posted the attachments to try to redo all the associations, there were no curves showing under the geometry tree? Is there a process that causes them to be deleted, or did I somehow accidentally delete them from the parts list?
Thanks again Far
Old   January 16, 2014, 11:10
Far
Sijal
may be curves are hidden or deleted accidently.
I have observed that after creating o-grid associations are released in versions 14 + . I think it is bug.
Old   January 16, 2014, 11:25
Thankfully I saved individual geometry and blocking files. I will need to learn more about ICEM. I think it's more powerful and I'm learning more about my generated mesh than Ansys Meshing
icem cfd 14.5
cgns grid problem praveen SU2 20 March 10, 2014 15:09
Ansys 12 Workbench problem when generating volume mesh Sveink ANSYS 5 January 6, 2010 04:17
Problem with Grid display avinash FLUENT 2 December 8, 2006 14:49
Problem on building grid operation (fluent) remy FLUENT 0 April 12, 2002 11:37
nonstaggered grid problem Zhi-Xing Yu Main CFD Forum 7 August 26, 1998 14:22
