January 14, 2014, 05:54 |
3D meshing of a tortuous blade
Rep Power: 12 |
I intend to mesh a turbine blade with hex cooper. But problems with skewed an even inverted elements arise on the leading edge I meshed the tip seperately, linked it to the hub face... due to the different geometry there it gets skewed already... when meshing the volume it takes quite a while to generate the mesh and then produces skewed and inverted cells Is there a way to for example spilt the faces in a way so that hex cooper is possible? I have not dealt with inverted elements and am not sure how to approach here |
January 14, 2014, 06:11 |
Maxime Perelli
Rep Power: 41 |
Where do inverted (skewed) elements come from?
from your BL or from your core-mesh?
In memory of my friend Hervé: CFD engineer & freerider |
January 14, 2014, 06:26 |
Rep Power: 12 |
I did a BL around the airfoil at hub and tip, there the elements look fine. So it must be the core mesh. Which is the face meshed with quad pave on the attached picture....
...but I am not entirely sure about the inverted elements. It kind of looks like those are in the BL and the skewed elements are caused by the meshed face at the leading edge |
January 14, 2014, 06:30 |
Maxime Perelli
Rep Power: 41 |
before you try some splits, you may try to increase the BL height
January 14, 2014, 06:56 |
Rep Power: 12 |
ok thank you, I tried that which still causes the linked face to end up skewed. See the picture: the face in front is ok, but the other one is skewed and will produce even more skewed elements when meshing the volume...
is it possible to do hex cooper without face linking the source faces? or do you have an idea to improve the quality of the linked face |
January 14, 2014, 07:03 |
Maxime Perelli
Rep Power: 41 |
you can also mesh your face with tri. The volume will still be meshed with cooper (wedge)
When I see your picture, it seems you mesh the first surface (in front of you ) first. And Gambit try to project your source-surface on the other (back surface), Try to mesh the back surface first. If it won't fix your problem, then you will have to split both source surfaces and you will try to mesh one source with quad (no pave)
January 14, 2014, 08:08 |
Rep Power: 12 |
what do you mean with your last sentence? I cannot imagine meshing one face in quad (why no pave?) and the other differently.... those faces need to be linked to my understanding
January 14, 2014, 09:28 |
Maxime Perelli
Rep Power: 41 |
pave is unstructured. Map is structured, and you have more control on your mesh.
You have to understand of course that both surfaces are map (or pave). But you only have to mesh one before you go and mesh the volume. In your case both surfaces don't have to be linked.
January 14, 2014, 12:06 |
#9 |
Rep Power: 12 |
when I only mesh 1 of the faces and then mesh the volume, the remaining face will be automatically meshed by gambit, so I achieve nothing... gambit crashed :/
why do you think, that there is no face linking needed in my case? |
January 14, 2014, 12:22 |
#10 |
Maxime Perelli
Rep Power: 41 |
Link faces only if you need periodicity.
In your case, Gambit meshes the other face because of the link.
January 15, 2014, 04:00 |
#11 |
Rep Power: 12 |
ah well, then I have not given you enough information: I definitly need the periodicity because this mesh will be extended circumferentially
January 15, 2014, 04:35 |
#12 |
Maxime Perelli
Rep Power: 41 |
But according to your pictures I cannot imagine your source faces are periodic
January 15, 2014, 04:47 |
#13 |
Rep Power: 12 |
yes, those faces itself are not periodic.... but the faces connecting those 2 are.
maybe the picture will help explain this, you see 1 blade, where the tip and hub are meshed via linking so that the outer faces (red and opposite) are periodic |
January 15, 2014, 04:58 |
#14 |
Maxime Perelli
Rep Power: 41 |
yes, now it is clear.
What is the quality if you mesh this volume with tetra? (just to be sure that your BL is clean) If you want you can also provide me the dbs file or at least only the volume which causes skewed elements
[ICEM] High Stagger Rotor Blade Meshing | eromon84 | ANSYS Meshing & Geometry | 12 | August 14, 2013 06:40 |
[ICEM] Incomplete blade Hexa meshing | m5edr | ANSYS Meshing & Geometry | 3 | June 22, 2013 16:36 |
[ICEM] Hexa meshing of Wind Turbine blade. Help for Newbie please | federvo.mala | ANSYS Meshing & Geometry | 4 | June 8, 2013 03:19 |
Meshing a 3D, tapered and twisted blade with Gambit-TGrid | teskio | ANSYS Meshing & Geometry | 0 | July 3, 2009 10:36 |
Question on blade meshing | Jeffrey | CFX | 0 | March 7, 2008 17:13 |
