[ANSYS Meshing] Hydrocyclone meshing in ICEM CFD
Old   January 2, 2014, 01:24
Default Hydrocyclone meshing in ICEM CFD
k1k
kedar
k1k is on a distinguished road
I am using ICEM CFD for hydrocyclone meshing. i have almost done the meshing but there is some issue with the "Uncovered Faces "which is i don't know how to solve. Actually the main problem is block connectivity which is not correct. I don't know how to connect different blocks together, which have different node no. i tried but didn't work ....
can any one help me regarding this issue???????
Thanks in advance....[
k1k is offline   Reply With Quote
Old   January 2, 2014, 01:29
k1k
kedar
Old   January 2, 2014, 09:30
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You can join blocks with merge block command or merge vertex command. But i would recommend that you start with single block and cut it into the required shape...
Far is offline   Reply With Quote
Old   January 2, 2014, 10:13
k1k
kedar
Hi Far
Thanks for ur reply......
I have tried join blocks with merge block option, it says blocks are unstructured so it is not possible to join. even i tried with merge vortex option also which is also not helpful because it won't covered the face which i mentioned in image 4...
i didn't try with single block so I ll give try with single block.
Thanks for ur suggestion .....Far
Old   January 2, 2014, 13:41
Far
Sijal
can you show the blocks where you have tried merge command and any message you got ?
Old   January 3, 2014, 02:26
k1k
kedar
Hi Far,
i extrude block 3 from block 1 & tried to merge block 2 & block 3.
when i tried to merge block 2 & 3, it says " Unstructured region", because no. of nodes of block 2& 3 are different that why it's not merging. ....
icem cfd meshing problem timothi61 ANSYS 2 July 16, 2013 15:22
[ICEM] problem with meshing in icem cfd saurabhjoshi2011 ANSYS Meshing & Geometry 13 March 12, 2013 12:27
[Other] Ansys Meshing vs Ansys ICEM CFD JuPa ANSYS Meshing & Geometry 5 September 19, 2012 10:48
[ICEM] Problems with meshing in ICEM CFD Benne ANSYS Meshing & Geometry 2 September 17, 2012 04:08
[ICEM] Helicopter meshing tutorial - ICEM CFD Far ANSYS Meshing & Geometry 0 May 20, 2012 12:10
