STL to Solid Body for CFD
Old   December 30, 2013, 11:15
Default STL to Solid Body for CFD
Sohail
sohailr is on a distinguished road
I am trying to convert the STL file of a wing with split winglets into a solid body to mesh in ICEM or Gambit. I can't seem to get it to work properly.
I've tried Design Modeler, Solidworks, Geomagic studio, and Meshlab. I was able to get some solid using the CSG in meshlab but it was very crude. The solidbody option in SWD won't work as there are too many faces.
Does anyone know how to convert this stl surface to a solid body? or how I can create the mesh to carry out CFD analysis of external flow? Step by Step instruction for either would be great.
Here is the link to the stl file.
https://www.dropbox.com/s/ppseb24lmp...ration.stl.zip
Thanks,
sohailr is offline   Reply With Quote
Old   December 30, 2013, 14:23
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Why do you need a solid?
lovecraft22 is offline   Reply With Quote
Old   December 30, 2013, 15:10
Sohail
I need it to be a solid if I want to mesh it in ansys.
Also if you can provide the steps to mesh where I won't need a solid, then that'd be great.
Old   December 30, 2013, 15:12
lore
Don't know about ansys and I don't know if it can take a surface as in input but most softwares do… You input your stl and then you create your domain around it.
cfd, csg, meshlab, solid body, stl
[DesignModeler] Merge Surface Body and Solid Body prikeyma ANSYS Meshing & Geometry 5 April 16, 2015 08:01
How to visualize the solid body in multiphase flow grid? asoltoon OpenFOAM Post-Processing 2 February 2, 2013 13:40
[DesignModeler] how to subtract a surface body from a solid body? yahya ANSYS Meshing & Geometry 4 January 7, 2013 12:00
cooling a solid body Ralf Schmidt FLUENT 1 April 16, 2007 11:54
creating a solid body in Design Modeller Dan CFX 0 May 24, 2004 12:59
