[ICEM] Problem with meshing 2D geometry
Old   December 18, 2013, 09:59
Default Problem with meshing 2D geometry
Nick
Nicolastheterminator is on a distinguished road
I have been having this problem for days, and I still don't understand what is wrong. I have been doing a 2D hexa mesh generation for 2 quadrilaterals together and just want to look at heat flux across them.
I create my points,lines and surfaces, and then create a 2D planar block. I cut the block into 2 separate blocks, and associate the lines to the edges. Then I associate each surface to the corresponding block face. When I load my mesh from blocking, I always get the problem of single edges around my mesh when i do a mesh quality check. Ansys Fluent consequently does not load the mesh complaining of zones not referenced by the grid.
Please can you help me?
Regards,
Nicholas
Nicolastheterminator is offline   Reply With Quote
Old   December 18, 2013, 22:39
kad
kad will become famous soon enoughkad will become famous soon enough
Single edges on the boundaries of a 2D mesh are normal. Look up the definition of single edge in the manual.
If I remember correctly the "zones not referenced by the grid" message shows up by default, when there is a mesh on both sides of a boundary, which would be the interface between the two blocks. I guess there is also a shadow zone created at the interface. For heat transfer over the interface the coupled wall option is the right way to go. Look up coupled wall in the fluent manual.
kad is offline   Reply With Quote
[ANSYS Meshing] Meshing problem in a constricted geometry kozden ANSYS Meshing & Geometry 0 December 18, 2013 04:39
[ICEM] Meshing on a Complicated Geometry tav98f ANSYS Meshing & Geometry 2 August 17, 2011 12:15
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
Problem meshing turb. blade tip clearance geometry Balu FLUENT 0 June 7, 2008 22:10
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
