[ICEM] 3D Straight-tube with inlet/outlet
Old   December 12, 2013, 14:03
Default 3D Straight-tube with inlet/outlet
BlackTomatoes is on a distinguished road
Hi all,
I am learning to mesh with ICEM from the basics, a 3D cylindrical straight-tube with a single inlet and single outlet. I managed to get a decent hexa-core mesh with prism layers along the wall. However, I found that parts of the surface mesh on the inlet and outlet has been replaced by the volume mesh and is no longer recognized as an inlet/outlet in Fluent. Could someone enlighten me on this. Is there something that I have missed out on? Alternatively, are there any tutorials related to pipe flow.
Thank you.
BlackTomatoes is offline   Reply With Quote
Old   December 12, 2013, 18:34
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
I don't know how that happened, any screenshots ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 13, 2013, 04:47
Hi, thanks for the reply. I've attached some screenshots. I'm also reading your book and it is definitely a good platform to start learning ICEM. Thank you so much for the effort.
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 03:10
[OpenFOAM] Tube filter in Paraview werweisswas ParaView 0 December 10, 2012 07:18
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 07:54
Problem with using icoFoam for flow in a straight tube edificelp OpenFOAM 4 February 11, 2011 04:27
Flow of tracer in a tube uma FLUENT 9 October 3, 2003 15:53
