[ICEM] Fix hanging nodes in 2D structure mesh after using block refinement
Old   December 12, 2013, 08:44
Default Fix hanging nodes in 2D structure mesh after using block refinement
Ted Sjöberg
Tedsjo is on a distinguished road
Hi there.
Is there any way to fix the hanging nodes you get from refining a block when creating a 2D structured mesh? The easiest way I can think of is by just splitting the first coarse element into three tri-elements. Is there any function in ICEM where one can do this?
See my picture for the problem and my thought on how to fix it.
Tedsjo is offline   Reply With Quote
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 09:07
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 03:32
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
