[ICEM] Mesh for Conjugate Heat Transfer Problem (2D)
Old   December 9, 2013, 10:23
Default Mesh for Conjugate Heat Transfer Problem (2D)
Marion
cymbourne is on a distinguished road
Hi all!
I'm having some problems getting a boundary layer in a conjugate heat transfer problem. I have 3 surfaces fluid_cold, fluid_hot and solid. I don't know how to create a boundary layer just for the fluid.
1- I created 1 part for each surface
2- I set the mesh parameters in the "part mesh setup" menu
2a - For both fluid domaines I checked "prism"
3- I computed the surface mesh
4- Icem generates a boundary layer on both sides of the line that separates the fluid from the solid
Any suggestions?
My geometry consists of 3 rectangles as follows:
|······· FLUID_COLD············|
|·········· SOLID··················|
|·········FLUID_HOT ············|
cymbourne is offline   Reply With Quote
Old   December 15, 2013, 13:56
Raghav
raghav is on a distinguished road
Please share the geometry in .tin format. It will be easy to work on with.
raghav is offline   Reply With Quote
Old   January 22, 2014, 01:55
Ashutosh
dreamz is on a distinguished road
Hey, did you get the solution to your problem. I am also trying to solve a similar type of problem...?
dreamz is offline   Reply With Quote
icemcfd
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Mesh suggestions for a conjugate heat transfer problem maddalena Main CFD Forum 1 January 25, 2013 18:39
Heat transfer problem at fluid-solid interface kiwikiwi FLUENT 4 January 14, 2013 19:47
best mesh generator for conjugate heat transfer? phsieh2005 Main CFD Forum 1 June 1, 2007 18:35
Electrolyte heat transfer problem fea user CFX 0 November 28, 2006 18:39
