[ANSYS Meshing] Split rectangular geometry in even squares |
December 9, 2013, 10:21 |
Tom Marquardt
Rep Power: 13 |
Hey,
I would like to split a rectangular surface body in 90x100 even elements. Can someone give me advice how to do it? Thanks! |
December 12, 2013, 05:53 |
Tom Marquardt
Rep Power: 13 |
Thanks for your respond!
If I understand you correctly this would split the geometry, but I dont want to change the geometry, just the mesh. I have a 400x12 mm rectangular surface and would like to create a mesh with 100x90 elements. How can I do this in the meshing tool? Thanks! |
December 12, 2013, 05:58 |
vidyanand
Rep Power: 18 |
use the virtual toplology on the bodies with help of split faces or eges,you can split the surfaces and mesh but its bit time conjuming compare to design modeller is easy method
December 12, 2013, 06:33 |
Alex
Rep Power: 49 |
In the Ansys meshing tool, switch off the "advanced size functions", apply a "mapped face meshing" to the surface and apply the "sizing" option to the edges.
Set the behavior of the sizing to "hard" and use "number of divisions" as type. Now you can specify the number of elements on the edges. |
December 12, 2013, 07:18 |
Tom Marquardt
Rep Power: 13 |
Thanks a lot guys! I will let you know as soon as I know if it worked.
December 12, 2013, 07:38 |
Tom Marquardt
Rep Power: 13 |
It worked out perfectly! Thanks a lot, I really appreciate your help...saved my ass here!
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 23:15 |
[ICEM] Automatic geometry preparation for hex mesh and circle curve splitting | waiter120 | ANSYS Meshing & Geometry | 2 | May 5, 2013 12:00 |
[Workbench] Meshing and export mesh from STL geometry | alerfreire | ANSYS Meshing & Geometry | 0 | March 26, 2013 10:25 |
[DesignModeler] problem with import geometry from catia | pavilion | ANSYS Meshing & Geometry | 1 | November 23, 2012 11:45 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
