[ICEM] how to reduce maximum cell skewness
Old   December 6, 2013, 13:13
Post how to reduce maximum cell skewness
adila anbreen
Adila Anbreen is on a distinguished road
i am working on ansys fluent...i have generated a mesh of perforated plate but eacb time i check the quality of mesh the warning comes" maximum cell skewness exceeds 0.98." i have tried different minimum and maximum sizes of cell but unable to resolve the problem.....please if anyone knows the solution help me.....it would be a very great favor....please...
Adila Anbreen is offline   Reply With Quote
Old   December 9, 2013, 01:35
muhammad hussain
hussain_2723 is on a distinguished road
This problem is due poor meshing, try the following....
check for hexahedral elements in 3D or quadrateral elements inn 2D. Also check for the refining methods.
hussain_2723 is offline   Reply With Quote
Old   December 9, 2013, 04:31
adila anbreen
how am i supposed to do that?
i am using ansys fluent 12.1 and in ansys 12, meshing method can be changed and i have tried all methods one by one... i did not find anything where i can change the shape of meshing elements...
option of refining the hexahedrals is available in earlier versions of ansys but i could not find it in ansys 12.
if you can help in improving mesh quality in ansys 12, it would be so nice of you...
Old   December 9, 2013, 09:05
muhammad hussain
well I am using ansys 14.0 and there is lot of options available for improving the geometry.
let me know your geometry and I will try to solve it but keep in mind that it also depends much on how complex is your geometry.
You can mail it to me
me1216@pieas.edu.pk
Old   December 22, 2015, 08:25
mohammad alaboud
mohammad-90 is on a distinguished road
Greeting to everyone ,,
I had the sme problem that Adila Anbreen has (maximum cell skewness exceeds 0.98)
how can I use hexahedral elements for my 3D geometry؟؟
mohammad-90 is offline   Reply With Quote
mesh quality problems: maximum skewness larger than 0.98 cth_yao FLUENT 4 May 19, 2016 11:59
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 15:38
Cell Skewness Affect Divergence? pyroknife FLUENT 4 May 27, 2013 04:10
[ICEM] 3D turbine blade modeling ShaneStan ANSYS Meshing & Geometry 49 December 4, 2011 14:48
how to reduce Cell Equivolume Skew santosh FLUENT 1 August 16, 2005 15:38
