November 20, 2013, 08:23 |
Free block issue
Mark
Rep Power: 13 |
Dear All
I wondered if someone could point me in the right direction here, I have attached a picture of my mesh and as you can see due to it being a cylinder with a extrusion you get a really dense region in the centre o-block. I thought what I would do for this is make the centre block free so I could impose a different element size on it in order to balance the element up. However, when I change the block to free the pre-mesh seems to turn into just a shell mesh even though I can clearly see the 3D blocks. Anyone got any thoughts? I am playing with refinement to achieve the same aim but it doesn't seem to want to accept values below one even though the help files says it should. Means I have to refine all the blocks round it which is a bit tedious Many Thanks Mark |
ansys icem, free blocks |
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 17:37 |
Comsol (4.3): convert parametric surface into block? | sgalaz | COMSOL | 0 | November 9, 2012 10:20 |
Linear analytical solution oto the 2D free sloshing water surface elevation | bearcat | Main CFD Forum | 7 | August 5, 2011 21:13 |
[ICEM] Quest for seemingly simple Blocking (degenerate block) | la7low | ANSYS Meshing & Geometry | 0 | July 12, 2011 20:48 |
gravitational force for free surface flow | Jongtae Kim | Main CFD Forum | 1 | July 2, 2000 12:57 |
