[ICEM] ICEM CFD meshing for a complex geometry
Old   November 20, 2013, 06:29
Unhappy ICEM CFD meshing for a complex geometry
Dj Chilli
djchilli is on a distinguished road
Hello everyone,
I'm a complete beginner in ICEM CFD and I would like some help. I have basically created a heat exchanger model in SolidWorks which I then imported to ICEM CFD to mesh. There are basically 21 rectangular channels which I successfully meshed. I have left triangular gaps in between the channels as you can see in the image, which I plan to mesh later. I have also meshed the outer boundary which is basically like a disk.
I'm finding it difficult to mesh the outlet and inlet basically. I modeled the outlet just like the 3d pipe junction in the tutorial so I could learn from the example, but it's not meshing it right, I think its because of the interface.
The inlet is basically a cylinder, but Im unable to mesh it properly too, possibly because of the interface at the other end of the inlet.
I would appreciate guidance on how to go about this, because I'm a complete beginner and I've been trying this for weeks without any results.
Thanks in advance
djchilli is offline   Reply With Quote
Old   November 21, 2013, 01:51
Dj Chilli
can someone please help me? I'd really really really appreciate it.
Old   January 10, 2014, 13:26
jpando is on a distinguished road
You need to setup the blocks for each part of the junction then create an o-grid on the faces which represent circles.
jpando is offline   Reply With Quote
cfd, icem, mesh
icem cfd meshing problem timothi61 ANSYS 2 July 16, 2013 15:22
[ANSYS Meshing] Meshing problem using ICEM CFD cgpa4 ANSYS Meshing & Geometry 2 November 4, 2012 13:22
Can't import geometry file from Icem CFD to Ansys Workbench Julien87 ANSYS Meshing & Geometry 1 July 19, 2011 17:50
flow over an airfoil 3d ( Geometry on icem cfd ) dfmona Main CFD Forum 0 April 14, 2010 00:32
ICEM CFD Meshing Problems: Hexa Dominant Evan CFX 6 July 3, 2006 13:37
