[ICEM] Tetra/Prism Mesh with Translational Periodicity |
November 12, 2013, 04:54 |
Stuart
Rep Power: 26 |
I'm making a tetra/prism mesh of a rectangular fluid domain for an external aerodynamics simulation in CFX. I would like the two side faces of the domain to have identical surface meshes (their mesh parameters are the same) so that I can make their boundary conditions in CFX to be a translational periodic interface, rather than use symmetrical boundary conditions. Is this possible with the global periodicity option? I find the best way to make tetra/prism meshes is to make an octree volume mesh, delete the volume cells, smooth, make a Delaunay volume mesh, smooth, make the prism layers and smooth. Will the periodicity be respected with this method? The User Guide says that periodicity with Delaunay in not applicable. Thanks |
November 12, 2013, 05:17 |
In your case you are going to make Delaunay mesh from the surface mesh. And surface mesh is obtained from the octree method and octree method respects periodicity!!!
Now the question is that does delaunay change the surface mesh in the process? If no then you have perfect mesh. |
November 12, 2013, 05:35 |
Stuart
Rep Power: 26 |
I should have also said that the base of the rectangular domain will be a no-slip wall, so it will have prisms on it. So will surface mesh on the sides respect translational periodicity with the prism layers are built up from the wall?
November 12, 2013, 11:00 |
But I have observed that in process, prism mesh (unless you play with advanced parameters) changes the surface mesh little bit. But that cab be corrected in the edit mesh menu. I haven't tried this all but i am going to do it on the 90 deg solid from cylinder.
November 20, 2013, 07:22 |
Stuart
Rep Power: 26 |
Does ICEM respect periodicity of surface meshes when smoothing is conducted? For example, if we smooth a mesh will ICEM make sure to movement of nodes on periodic faces is identical.
After some testing I can answer my own question. Yes, it does respect periodicity when smoothing and making prism layers. Last edited by siw; November 20, 2013 at 09:04. |
April 9, 2015, 12:05 |
Simon Harbeke
Rep Power: 11 |
Anyone got some tips regarding the smoothing of a tetra mesh with rotational periodicity?
I mostly find the bad elements where periodic faces meet with non periodic faces. Of course one can move the bad periodic node, improve the specific element and then adjust the other node by using the repair/make periodic tool, but that's not really automated. Any hints? |
March 26, 2020, 16:16 |
Tim
Rep Power: 10 |
Hello, I am doing something similar as described in the first post.
Did you come up with a way to accomplish this? I think I will try 1. Octree mesh (no prism layers) 2. Delete volumes 3. Smooth surface mesh 4. Delaunay volume mesh 5. Generate prism layers Will the prism layers generated after the Delaunay volume mesh respect the rotational periodicity? |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 14:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
