[ICEM] Ogrid not successful
Old   November 10, 2013, 00:57
Default Ogrid not successful
clocter
clocter is on a distinguished road
All,
I am having problems running an ogrid through pipes - error msg - ogrid not successful.
My geometry is as follows-
Inlet-splits into a loop-combines again-Outlet ( 2 Y shapes inverted)
I generated the blocking by extruding the faces and when it splits into a loop and then merge vertices when they combine again.
When i try applying an ogrid it is not successful.
I tried renumbering, resetting ijk of the blocks - its still not working.
Is it because the blocking was separate and the ogrid does not see connectivity?
Thanks
clocter is offline   Reply With Quote
Old   November 10, 2013, 01:47
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
there may be the association problem.
Far is offline   Reply With Quote
Old   November 10, 2013, 04:39
clocter
Thanks for the reply.
So are you suggesting that I completely associate all the edges/curves and then run the ogrid through the pipes?
I will try it out, but I thought association is not related to generating an ogrid?
Regards
DJ
Old   November 10, 2013, 06:40
Far
Sijal
Yes. Some times it makes problem or if blocks are not connected.
[ICEM] ogrid to h-grid connection Teradil ANSYS Meshing & Geometry 2 March 4, 2013 05:59
[ICEM] 2D Airfoil Meshing (Ogrid) mrenergy ANSYS Meshing & Geometry 1 December 22, 2012 12:45
[ICEM] unwanted pre-mesh inflation around Ogrid macfly ANSYS Meshing & Geometry 7 September 25, 2012 10:41
y+ Value & Aspect Ratio {Wind Tunnel Model} FabioT ANSYS Meshing & Geometry 18 October 5, 2010 16:00
ogrid in ogrid susan CFX 4 December 20, 2007 06:58
