[BladeModeler] Bladegen data import wizard
Old   November 6, 2013, 03:58
Arrow Bladegen data import wizard
Arslan
ArslanOZCAN is on a distinguished road
Hi everyone;
I draw a 3D hydraulic turbine blade in Solidworks and import it into Ansys Bladegen in Igs format using Data import wizard. I submitted whole step but at the last step it asks for Leading Edge and Trailing Edge eliptic ratio. There are red squares, at both LE and TE and asks to confirm these points. How should i replace and submit them? What are these squares defining?
When i pass this step and open the final geometry in TurboGrid or Design modeler trailing edge is generated as cutted randomly which is wrong. What can be the problem ?
Best Regards.
ArslanOZCAN is offline   Reply With Quote
Import to Bladegen hasbi CFX 13 November 9, 2014 05:42
[Other] [DesignModeler] import data XYZ zelito ANSYS Meshing & Geometry 0 December 15, 2009 15:48
Import validation data to CFX Post Vattenkraft CFX 0 November 26, 2009 20:55
import spline data format Chris Siemens 0 March 30, 2005 14:09
I-DEAS CAD data import with boundary conditions Yunus Siemens 1 June 1, 2001 11:04
