[ICEM] Hybrid mesh hexa and tetra on ICEM
Old   October 22, 2013, 13:22
Default Hybrid mesh hexa and tetra on ICEM
Jun
PeterDaniel is on a distinguished road
My name is Jun, I am a PhD student and I need some help to generate a Mesh for my computation.
I am trying to mesh a simple geometry (3 cylinders with the same diameter)to get familiar before working on my final geometry.
The mesh I want to obtain will be compose of an Hexa domain followed by an tetra one and finally an other Hexa domain. I will add later prismatic layers at the boundaries.
I tried to mesh each part separately and then merge everything.
Everything goes right for the Hexa mesh. I save the end of this part as a mesh and imported to the next part which will be in tetra. The problem is that when I use this surface mesh for the next part, ICEM does not generate any pyramids to make the transition. It simply split every surface quads into tri. Does anyone has an idea about what i did wrong? Or is it possible to merge two cylinders which have the same diameter?
Thank you in advance,
Jun
PeterDaniel is offline   Reply With Quote
hexa, hybrid mesh, icem 14.0, prims, tetra
[ICEM] Need urgent help for hybrid mesh generation Pursuor ANSYS Meshing & Geometry 1 August 29, 2012 17:04
Solution on hexa mesh vs solution on tetra mesh Chander CFX 2 December 10, 2011 10:35
Hexa + Tetra meshing (Hybrid) in ICEM vmlxb6 ANSYS Meshing & Geometry 12 December 27, 2010 11:18
[Other] hexa vs hybrid mesh convergence Viais OpenFOAM Meshing & Mesh Conversion 0 April 23, 2010 11:39
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 07:46
