[TurboGrid] Ansys Turbo Grid: Import Geometry Problems |
October 21, 2013, 04:25 |
Rep Power: 13 |
iam searching for a solution to import points into ansys turbo grid. unfortunately i have just the blade geometry with the points in x,y,z positions. So i added two points as shroud and two points as hub. after doing this, turbo grid had the error: ERROR Start and end parametric value are identical. ERROR Trim operation failed to produce any surfaces for surface Blade_1_tr_cl. ERROR Trim operation failed to produce any surfaces for surface Blade_1_tr_low. Has anyone a good idea how i could fix this problem? thanks a lot! |
July 31, 2015, 17:32 |
David Valladares
Rep Power: 13 |
Hi Polito, now I am having the same problem you posted a couple of years ago and I am interested to know if you solved that problem and how you did it.
Thanks a lot |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
Mesh and geometry import in cfx-pre | Francesco | CFX | 7 | May 30, 2012 08:04 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Import plot3d grid file | CFX new user | CFX | 1 | November 24, 2001 16:10 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
