[TGrid] Import geometry problems
Old   October 18, 2013, 08:33
Default Import geometry problems
Polito is on a distinguished road
iam searching for a solution to import points in turbo grid. unfortunately i have just the blade geometry with the points in x,y,z positions. when i try to chose this data as profile.curve nothing happens. has somone a good idea how to fix this?
thanks a lot!
Polito is offline   Reply With Quote
Old   October 20, 2013, 23:18
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Turbogrid and TGrid are (very) different programs. Maybe edit your title or you may not get a reply.
Stu
stuart23 is offline   Reply With Quote
[DesignModeler] Import external geometry problem Houman ANSYS Meshing & Geometry 0 May 16, 2012 05:24
Can't import geometry file from Icem CFD to Ansys Workbench Julien87 ANSYS Meshing & Geometry 1 July 19, 2011 17:50
Problems with PLOT3D import in GAMBIT AleDR ANSYS Meshing & Geometry 2 May 6, 2011 11:21
Import Geometry Gambit Henri79 ANSYS Meshing & Geometry 0 May 7, 2010 03:44
IMPORT GEOMETRY FROM SOLID EDGE Jibran Haider FLUENT 1 July 11, 2008 05:03
