October 14, 2013, 02:14 |
#21 | |
Maxime Perelli
Rep Power: 41 |
In memory of my friend Hervé: CFD engineer & freerider |
October 14, 2013, 11:13 |
#22 |
Rep Power: 16 |
I tried other axis it plot a volume but it incorrect? may u fix me this problem i complete the plot just this small part remain and i already sent the jou file.
October 15, 2013, 02:06 |
#23 |
Maxime Perelli
Rep Power: 41 |
post picture please
October 17, 2013, 17:33 |
#24 |
Rep Power: 16 |
Hi I post three pictures first one for the face i plotted before revolving, the second after i revolve it around y-axis and the third when i revolve the face around x-axis? as you see the volumes in both pictures seems incorrect? when i tried revolve the face around the z-axis it give me error : ACIS error 78074 the sweep surface is in-self intersecting surface? so Please help me to fix it?
mariam |
October 18, 2013, 01:28 |
#25 |
Maxime Perelli
Rep Power: 41 |
picture 2 gives you the answer
... you have to move your cross section such as its rotation axis matches the y-vector of your coordinate system (or you can create another coordinate system). But as I see your pictures, the 2 blue points which are supposed to describe the revolution axis doesn't seem to be colinear
October 18, 2013, 09:46 |
#26 |
Rep Power: 16 |
Did you mean by moving the cross section is making the y-axis coordinates at the middle of the plot? can you send me picture about this?
About the two blue points it looks located at the same line? why it not colinear? |
October 18, 2013, 09:58 |
#27 | |
Maxime Perelli
Rep Power: 41 |
-"colinear" is wrong explained, sorry. I wanted to say that the line should be parallel to rotation-axis AND the revolution axis shouldn't cross the section. In my picture the red surface is "wrong" Untitled.png
November 3, 2013, 05:45 |
#28 |
Rep Power: 16 |
hey max i plot the geometry and revolve the surface successfully then i unite the volumes into one volume but i face an error with mesh please see picture. There error mentioned in it.
November 4, 2013, 02:34 |
#29 |
Maxime Perelli
Rep Power: 41 |
your central volume is wrong built: you can see it with its mesh.
November 5, 2013, 06:43 |
#30 |
Rep Power: 16 |
How i can fixed it? what i can do?
November 5, 2013, 07:12 |
#31 |
Maxime Perelli
Rep Power: 41 |
Explain how you built it
November 5, 2013, 08:33 |
#32 |
Rep Power: 16 |
I create a surface then revolve it as seen in picts 1,2,3 as you told me? then i reflect volume 1 to have the third volume after that i unite the three volumes then i mesh the final volume with cooper?
November 5, 2013, 08:57 |
#33 |
Maxime Perelli
Rep Power: 41 |
ok once all volumes are created, unite them, because you will have skewness problem at "interfaces" between curved volumes and your volume.2
Now you have only one volume, and you can mesh it
November 5, 2013, 10:33 |
#34 |
Rep Power: 16 |
I unite all of it and i predict one volume but it told me the error that i mentioned u at my previous post? what i can do to overcome the skewness problem at interfaces?
November 5, 2013, 10:42 |
#35 |
Maxime Perelli
Rep Power: 41 |
ah yes it failed because you want cooper.
But if you try tetra, it should be successful. If you want cooper, you need some works. But first be sur that your volume is ok
November 5, 2013, 11:27 |
#36 |
Rep Power: 16 |
I will see if it work with tetra? but with tetra is it effect the accuracy of results?
November 7, 2013, 16:22 |
#37 |
Rick
Rep Power: 27 |
Maybe..with tetra use green gauss node based and second order upwind schemes to have more accurate results.
Daniele |
[DesignModeler] DesignModeler Pipe within pipe | shields | ANSYS Meshing & Geometry | 13 | November 25, 2018 23:14 |
Double Walled Pipe Boundary | dahvqaz | FLUENT | 2 | December 5, 2012 11:14 |
plot Pressure drop in pipe | monty_p20 | FLUENT | 0 | November 17, 2011 18:18 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
