help me pls
Old   October 5, 2013, 12:45
Default help me pls
sooraj
str6073 is on a distinguished road
Hi i'm modelling a water heater in fluent . I'm very late on my schedule ,so don't have much time for studying all the things. so i need help in meshing my geometry to the minimum skewness.Can you guys please help me??
U can get the files here.
https://www.dropbox.com/s/03jqgtt7uprgv5m/Dropbox.rar
str6073 is offline   Reply With Quote
Old   October 6, 2013, 06:28
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You can mesh this model with full hexa in ICEM CFD. or alternatively you can mesh this model in ansys meshing with hybrid mesh (tetra + prism)
Far is offline   Reply With Quote
Old   October 6, 2013, 07:25
sooraj
thanxx for replying. I don't know how to use icfm cfd either.It will be really helpful if you can do the meshing for me.
Old   October 6, 2013, 12:21
Default Water heater
Javi
FJSJ is on a distinguished road
Hi Sooraj,
here you can download a first aproximation to your problem with full hexa mesh. Maybe.. this is not the best approach but... you can improve it from this first aproximation. Hope it īll be useful!! :-)
https://www.dropbox.com/s/216sqmtugp...r%20Heater.rar
FJSJ is offline   Reply With Quote
Old   October 6, 2013, 14:21
Far
Sijal
Another similar approach
Download Here
Old   October 7, 2013, 04:32
sooraj
thank you guys.. but how can i import this mesh into fluent so that i can simulate ??
Old   October 7, 2013, 06:53
Far
Sijal
in icem cfd, go to output tab :
1. select solver as fluent v6 or ansys fluent
2. set boundary conditions
3. output mesh
Old   October 14, 2013, 06:23
sooraj
hey guys thanxx for your hlp.I really appreciate it.Sorry about late reply. I could not import the files you gave to fluent or cfx.So can you mesh an .igs file to min skewness so that i can directly use it in fluent ??
https://www.dropbox.com/s/ncu2lya3d2...aterheater.igs
Old   October 14, 2013, 10:28
Far
Sijal
is it the same file?
Old   October 14, 2013, 11:04
sooraj
yes same geometry
Old   October 14, 2013, 11:18
Far
Sijal
Originally Posted by str6073 View Post
yes same geometry
But we have already posted mesh in the forum
Old   October 14, 2013, 11:42
Far
Sijal
https://dl.dropboxusercontent.com/u/68746918/fluent.msh
File in .msh format (fluent), but you can read in CFX as well
Old   October 15, 2013, 01:49
sooraj
Thank you buddy for this file.But there's a slight problem . The geometry i sent you, there the tube is sliced horizontally, so that i can give different heat fluxes on top and bottom of tube.But the file you sent,tube is a whole part and i can't give different heat fluxes. Can you please upload the right geometry ?? unit is in millimeters
HELP PLS: Simplefoam manipulated to add diffusive mass transport...but solver stops!! 1gn0rant OpenFOAM Running, Solving & CFD 1 August 13, 2010 12:02
help me understand porous media in fluent~ pls pls.. :( naftalena FLUENT 0 February 28, 2010 13:20
i need help following problem pls pls help gmani CFX 4 March 31, 2009 10:39
multi phase flows....pls help... karthik FLUENT 0 November 16, 2005 10:15
help pls gianluca FLUENT 2 November 12, 2004 11:27
