[ICEM] Dealing with thin internal walls in geomety |
October 3, 2013, 18:28 |
Matthew Rich
Rep Power: 13 |
Hi all
slowly but surely making progress in ICEM and have a working case in CFX. In an effort to get my quality up before prism meshing I wanted to know how to deal with geometry with internal walls that are really close together. The octatree mesher wants to jam low quality elements in there and I am not sure how to fix. I have tried knocking out points and lines and that does not work either. I am trying to keep my element count down so I do not want to refine everything to death. I have a big domain as is. Any advice. pic is attached. Thanks in advance. |
October 4, 2013, 12:56 |
Adrian
Rep Power: 14 |
Is this a single surface, or two surfaces in close proximity?
www.idacireland.com |
October 4, 2013, 12:59 |
Matthew Rich
Rep Power: 13 |
two surfaces close together. It was formed due to a divider wall in the geometry. I am doing a tet mesh and it jams elements in there that are of a low quality. I do not want refine to much since this region really is not that important but I wanna fix for future reference plus it seems silly not to be able to figure out a work around.
Any suggestions are much appreciated |
October 4, 2013, 13:00 |
Adrian
Rep Power: 14 |
Have you tried thin cuts and/or lowering the edge criterion??
Or actually; these are two internal walls in close proximity, and you do want to have cells in between them? It's hard to tell what's going on from your image.
November 13, 2013, 12:16 |
Matthew Rich
Rep Power: 13 |
thanks for the suggestions.
I did try thin cuts which did not help much, I been seeing that thin cuts in only for edges that come together at a shallow angle. I did lower the edge criterion, are there down sides to having too low a number? I was able to get a mesh that worked in CFX but my quality was never very good. |
[ICEM] Defining Interfaces and Splitting Internal Walls ICEM-FLUENT | pmtgt | ANSYS Meshing & Geometry | 8 | June 4, 2021 08:15 |
[blockMesh] Internal Walls | balkrishna | OpenFOAM Meshing & Mesh Conversion | 7 | September 11, 2019 18:04 |
[Commercial meshers] How to get rid of internal walls (surfaces)? | bmikuz | OpenFOAM Meshing & Mesh Conversion | 17 | December 5, 2013 16:24 |
[snappyHexMesh] Boundary Patch definition on Thin Surfaces / Internal Walls in SnappyHex | Hannes_Kiel | OpenFOAM Meshing & Mesh Conversion | 4 | August 27, 2013 02:06 |
[snappyHexMesh] Thin Surfaces / internal Walls in SnappyHex - Problem with patch allocation | Hannes_Kiel | OpenFOAM Meshing & Mesh Conversion | 0 | September 6, 2011 07:28 |
