[ICEM] Meshing of 2D cylinder / number of nodes |
September 22, 2013, 12:53 |
Leonidas Siozos-Rousoulis
Rep Power: 13 |
I have been trying to mesh a 2D cylinder configuration in ICEM (according to the following tutorial) and I want to make a denser mesh downstream of the cylinder.
http://www.youtube.com/watch?v=T2Dxa0OZf58 I am thus trying to add more grid points on the downstream edge, compared to the upstream edge. However, when selecting the downstream edge ("D" on the image) and increasing the number of points (without selecting "copy parameters on parallel edges"), the number of points automatically increases on the upstream edge ("U" on the image) as well. http://i593.photobucket.com/albums/t...2dcylinder.png Is there a way round to this? |
September 22, 2013, 22:22 |
Ghazlani M. Ali
Rep Power: 29 |
The need to have the same number of nodes ! that copy to parallel edges does not mean it will copy the number of nodes ! it's about the node's law distribution...
September 23, 2013, 06:05 |
Rep Power: 13 |
thank you for your answers.
however, the inside block is already deleted. any other way round to this? could it be an issue of the way the curves are associated to the surrounding edges? |
[ICEM] Assigning different number of nodes to parallel edges | Rohit | ANSYS Meshing & Geometry | 3 | September 22, 2017 10:16 |
Cylinder Intake Meshing | dbagtbag | CFX | 11 | July 30, 2015 08:59 |
Problem with decomposePar tool | vinz | OpenFOAM Pre-Processing | 18 | January 26, 2011 03:17 |
Interpolation (Number of mapped nodes) | Sam | CFX | 3 | January 6, 2008 20:51 |
Number of nodes on block. | Felix | CFX | 0 | October 24, 2007 23:26 |
