September 15, 2013, 10:40 |
2D mesh body of influence
Is it possible to use body of influence for 2d surface body in ansys meshing
tnx in advance solved tnx |
February 8, 2017, 20:06 |
Fariz
Rep Power: 11 |
i'm having the same issue in 2D. Where there is no BOI option in the dropdown list inside the "face sizing" section.
May i know how you solve it? or anyone else can help me regarding this? edit: solution found. Last edited by mfim88; February 12, 2017 at 22:08. |
November 7, 2017, 09:42 |
Body of influence
saurabh kumar gupta
Rep Power: 10 |
will you please explain how to use it?
thanks saurabh |
November 21, 2018, 09:14 |
2D Body of Influence
lucas s
Rep Power: 13 |
As nobody edited the solution here it is:
The answer is yes you can use a body of influence either in 2D or 3D. As called it is a body of influence and not a face of influence. Then you have first to select the body you on which you want to apply a sizing. And then you select the body of influence. Lucas |
March 27, 2023, 11:54 |
Rep Power: 6 |
The above "solution" does not work. Using actual bodies always worked fine for me.
Now I am doing an axisymmetric 2D simulation --> I don't have any bodies and only faces. "Use Adaptive Sizing" is already set to "No", as is proposed by the Ansys Meshing Guide. Any other ideas how to solve this (or at least the info if it is possible at all). Thanks! Edit: You actually have to select "Body (Ctrl+B)" and not "Face (Ctrl+F)" in Ansys Meshing and then it works. The 2D Face is regarded as a Body by Ansys Meshing... |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
Sliding Mesh - moving body | rw511 | FLUENT | 3 | May 9, 2013 02:37 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
