[ICEM] Edge Params linked
Old   September 10, 2013, 16:14
Default Edge Params linked
Jason
jasonbot is on a distinguished road
I am trying to apply edge parameters to a blunt TE of an airfoil. I created a C-grid around the airfoil and made the grid on the TE extend from the TE to the end of the domain.
Every time I try to change the number of nodes at the TE the number of nodes at the LE changes as well.
any ideas?
jasonbot is offline   Reply With Quote
Old   September 10, 2013, 19:28
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
Oh, I see. Can you post some more pictures showing your blocking? I may be able to help you.
Regards,
César
cesarcg is offline   Reply With Quote
Old   September 11, 2013, 12:42
kad
kad will become famous soon enoughkad will become famous soon enough
I guess you did not delete the blocks inside the airfoil permanently. By deleting blocks not permanently they are added to the part VORFN. For blocks in VORFN no mesh or premesh will be generated. But they still exist in the logiacal structure of the mesh. That is why changes in numbers of node at TE also apply to LE. So a simple solution should be to delete these blocks permanently.
kad is offline   Reply With Quote
Old   September 11, 2013, 14:49
Jason
I'm not too sure what happened but I've redone everything and its all working now.
I'm new to ICEM so I've been trying to do this mesh for a while now with not many results, I'm mainly doing the same thing over and over again, messing around with settings etc in order to get a hang of meshing.
Old   September 11, 2013, 17:34
Cesar
take a look at the video by simon. it may be able to help you giving you some ideas of block splitting and edge associations.
http://www.youtube.com/watch?v=tYrbScUH9RE
Old   September 16, 2013, 08:50
Jason
The video tutorial was helpful! After some frustration I'm getting the hang of ICEM meshing for airfoils.
airfoil, blunt te, icem
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
ICEM Extrude faces - Edge params. Santiago Orrego. CFX 0 June 19, 2007 13:08
