[Workbench] Parameters to control geometry on Workbench
Old   September 9, 2013, 11:52
Question Parameters to control geometry on Workbench
Romulo
djangana is on a distinguished road
I know the basics on how to work with Parameters on Workbench (assign values, assign expressions with other parameters, etc...).
I was wondering if there is any way to make parameters work beyond altering measures?.
Example:
I want to model a shell and pipes heat exchanger. Alongside with the dimensions of shell and pipe being parameters I would like to have the number of pipes on the exchanger as a parameter. Like turning "on/off" the pipes on the geometry, or allowing the change on one parameter to alter the configuration of the pipes.
Is anything like this possible?
Thank you for your help
djangana is offline   Reply With Quote
Old   September 13, 2013, 04:35
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
If you create the pipes with the "Pattern" tool in Design Modeler, you can set number of copies as a parameter
jrunsten is offline   Reply With Quote
Old   September 16, 2013, 12:39
Romulo
Thank you jrunsten, while that was not what I was looking for specifically, it helped me solve my problem
geometry, parameter
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
exports geometry workbench to ICEM TallesC CFX 4 December 1, 2012 16:08
[Other] Geometry in Workbench Keeps Closing DavidA ANSYS Meshing & Geometry 3 February 22, 2010 12:54
Control flow with the geometry dungsidietquy Fluent UDF and Scheme Programming 0 November 5, 2009 20:06
Virtual/Real geometry. Jack Keays FLUENT 9 June 16, 2000 00:39
