[ANSYS Meshing] Delauney from Surface Mesh ( ATTN: Far, Simon, Ali, Stuart :)) |
August 24, 2013, 22:41 |
david
Rep Power: 14 |
Is it possible in ICEM to create a surface mesh and then fill it up using the Volume mesh method? I read on one of the Forums here that you would need to do a volume mesh first, delete the volume, smooth like crazy and then do a delauney. My question is : Can u do a surface mesh and then do a delauney without having to go through the Octree method first?
August 25, 2013, 05:06 |
Rep Power: 20 |
Yes you can do it. First create the Shell Mesh and then directly fill the volume by Delauney Method. There is also a tutorial that came with the Ansys Help Package Wing Body tutorial about it.
August 25, 2013, 05:29 |
Stuart
Rep Power: 26 |
I've always used the octree volume mesh then deleted the volume cells method because I find it makes the better quality surface meshes (after the checking and smoothing). All that's needed is a watertight domain from the build topology. I've tried the surface mesh and then Delaunay but I found the octree volume generated surface mesh always was of a higher quality and nicer element distributions. Also you are forced on the mesh sizings by the octree rule, which is a good thing for me as I'm someone who tries to justify their mesh sizings and if I'm given too much freedom I'll spend ages trying too many variations and never get around to the CFD.
The main down-side is that it can take up a lot of PC memory with all those volume elements, which your PC might not have. But just last week I made a bunch of 10-12 million element meshes on my 4 core 20GB RAM PC this way and each octree meshing time was a good excuse to take a tea break. |
August 25, 2013, 16:35 |
#4 | |
But the real advatange of ICEM is in using hte OCTREE method if you can think in power of 2 and you can probabaly mesh the very complex model in less than hour and submit to solver. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 12:45 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
