[ANSYS Meshing] Problem with ANSYS Meshing - how to refine?
Old   August 21, 2013, 15:00
Default Problem with ANSYS Meshing - how to refine?
pyroknife is on a distinguished road
I attached a picture of the problem I am experiencing. The attached pic shows 2 views of the object of interest. I am having an issue with the top part as you can see. It's unable to generate elements for part of that geometry.
What kind of sizing option (face, edge, body) would be the best to solve the problem? Of if localized sizing isn't the best way to fix it, what other options are there?
pyroknife is offline   Reply With Quote
Old   August 22, 2013, 02:39
Paritosh Vasava
vasava will become famous soon enough
You can start by selecting 'fine' in the 'sizing' section. Also play with 'min size', 'max face size', etc.
You may also impose number of nodes on a faces or vertices via 'sizing'. Refinement can be done via 'refine' option in 'mesh control'.
Play little bit and lets see what you get.
vasava is offline   Reply With Quote
Old   August 22, 2013, 14:30
Thanks for the reply.
By selecting fine, do you mine selecting 'fine' under "relevance center" in the "sizing" tab? What does that do?
[ICEM] Meshing problem in Formula one Far ANSYS Meshing & Geometry 113 April 23, 2013 13:36
[ANSYS Meshing] Meshing Problem in worbench elina ANSYS Meshing & Geometry 0 March 31, 2013 09:53
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 01:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
[ANSYS Meshing] Ansys meshing with extended meshing jsm ANSYS Meshing & Geometry 6 January 10, 2011 13:09
