August 10, 2013, 08:37 |
Refinement criteria
Harry
Rep Power: 13 |
Hello friends. I am simulating flow around 2D airfoil (incompressible and laminar flow). I generated mesh using ICEM CFD 14.0. I am comparing my result to some experimental results. I want to know about the refinement criteria.
In my case, does refinement means that i should put more grid points on airfoil or i should decrease the distance of layers near airfoil boundary or both? I will thankful for help.. |
August 10, 2013, 12:33 |
#2 | |
Rep Power: 13 |
Find me online here. |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 03:32 |
[snappyHexMesh] snappyHexMesh refinement regions ignored | guitarbren | OpenFOAM Meshing & Mesh Conversion | 2 | April 9, 2013 04:59 |
[snappyHexMesh] Weird snapping outside a refinement region | jasimpson89 | OpenFOAM Meshing & Mesh Conversion | 0 | July 29, 2012 21:46 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 18:12 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
