[GAMBIT] Accessing geometry from Fluent Case file
Old   August 7, 2013, 18:44
Default Accessing geometry from Fluent Case file
James
JAlbert is on a distinguished road
Dear All;
I have a Fluent case file, but no corresponding *.msh or Gambit *.dbs files. I want to clear mesh and access to its geometry. When I import the case file into Gambit 2.4, an error appears " fe4317.exe has stopped working". I think it is because of 15 million elements. Any Idea Why this happens or how can I get the body geometry without meshes?
Win 7 64 bit, Exceed 64 bit.
Thanks a lot.
JAlbert is offline   Reply With Quote
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 15:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
