[ANSYS Meshing] Meshing 25 micrometers gap
Old   July 30, 2013, 05:20
Default Meshing 25 micrometers gap
Mr.H is on a distinguished road
I'm trying to create a mesh with inflation for my case, but I have a trouble with that I have a tube with diameter 57 mm and inside of the tube I have a plate which is rotated 8 degrees from axes of the tube and has a elliptic shape with 2a=56,910mm and 2b=56,984mm so it create only about 25 micrometers gap between plate and tube and i have a problem with meshing this room. I can't use any inflation. I guess it is because of the small distence but I'm not sure.
Here is the warning message when I try to create a mesh with inflation:
Patch-conforming tetrahedron mesh failed possibly because of bad boundary or inflation mesh.
Can anyone help me?
Thx
Mr.H is offline   Reply With Quote
Old   August 6, 2013, 09:18
Paritosh Vasava
vasava will become famous soon enough
Can you post pictures from your case?
vasava is offline   Reply With Quote
Old   August 9, 2017, 07:43
toofoxy is on a distinguished road
Originally Posted by Mr.H View Post
Can anyone help me?
Thx
Did you solve this problem?
toofoxy is offline   Reply With Quote
[GAMBIT] Error: small gap in meshing with Tgrid gdebadrawada ANSYS Meshing & Geometry 1 April 19, 2013 05:21
[snappyHexMesh] Meshing a small gap between walls staustrahltriebwerk OpenFOAM Meshing & Mesh Conversion 1 July 23, 2012 12:46
BL meshing airfoil with gap ghost FLUENT 18 December 1, 2009 23:47
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
