[ICEM] penetrating elements
Old   July 29, 2013, 13:27
Default penetrating elements
robboflea is on a distinguished road
I am having problems with penetrating elements coming out of my mesh check and I don't know how to get rid of them. I am modelling a 3d turbine airfoil and my penetrating elements all lay on hub surface or at the interface between the blade and the endwalls. Attached are some pictures, the penetrating elements are the red subset. There are a few visible (though quite small elements) as red lines on the blue blade edges at the tip and some at the hub.
What can be the reasons for having penetrating elements? What are the most common ways to solve the problem?
Thanks a lot in advance!
robboflea is offline   Reply With Quote
Old   July 31, 2013, 10:14
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
If you are using the blocking method, this can be an issue of vertex to point and edges to curves association. You should also check if the faces are being associated to the surfaces you want them to, otherwise, correct that.
Let me know whether yes or no you solve the problem.
Regards
cesarcg is offline   Reply With Quote
Old   July 31, 2013, 19:43
Thanks for the hint.
I double checked and it looks like all curves are associated correctly (at least I think so), so the vertices and the block faces.
Any other ideas?
Thanks
Rob
Old   July 31, 2013, 20:03
Cesar
Could you post some pictures of the blocking in the region that you are having problems with the penetrating elements?
Regards.
César
Old   August 1, 2013, 05:31
Default Answer
sadjad.s's Avatar
sadjad
sadjad.s is on a distinguished road
Send a message via Yahoo to sadjad.s
Hi mate,
i encountered this error while i was working with blocking and converting to unstructured mesh and using mirror option. (under transform options).
But when i exported it to fluent there was no problem.
So ignore it and export it to make a try.
ICEM, CFX and Fluent expert
sadjad.s is offline   Reply With Quote
Old   August 1, 2013, 05:36
I'll give a try in Fluent and see if it gives back something reasonable.
Thanks for the hint
Rob
Old   August 1, 2013, 14:17
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Run a cutplane or scan plane across the trailing edge and zoom in to see the reason why...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   August 1, 2013, 14:24
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Are you using ICEM CFD HEXA? If yes can you show some blocking pics?
Far is offline   Reply With Quote
Old   August 3, 2013, 10:57
Hi Far,
yes I am using hexa meshing. Attached is a picture of the blocking. Is a "shifted periodic" blocking.
Old   August 3, 2013, 11:31
Far
Sijal
Use scan plan to pinpoint the problem area as suggested by Simon.
For further details take a look on following thread. Simon has given a detailed explanation of many options in ICEM CFD Hexa for turbomachinery meshing.
http://www.cfd-online.com/Forums/ans...l-turbine.html
Old   August 3, 2013, 15:31
Thanks for the hint. I am still not able to come to anything meaningful as an explanation. Btw what is the exact definition of "penetrating element"? From the manual I seem to understand that they are elements, laying on external surfaces who intersect other surface elements.
If I am correct then penetrating elements should always be numbered in couples. Am I right? Why when I create a subset out of my problematic elements I see these penetrating elements alone?
Sorry for the question if it sounds stupid.
Thanks for the help
Rob
[ICEM] Hybrid mesh for 2D boundary layer Bigio ANSYS Meshing & Geometry 33 November 18, 2019 10:15
[ICEM] ICEM MRF Interface - Penetrating Elements survADe ANSYS Meshing & Geometry 9 February 4, 2015 03:26
[ICEM] Negative Volumes & 7 node HEXA elements mr_stoked ANSYS Meshing & Geometry 1 September 21, 2010 13:45
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 09:06
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
