[GAMBIT] Reg:Modeling of wing tunnel for drag test
Old   July 23, 2013, 17:05
Default Reg:Modeling of wing tunnel for drag test
ravi
pendyala is on a distinguished road
Hello All,
I modeled a wind tunnel(Gambit)to capture the flow around pickup truck., Now when I want to add small adjustments to the end of pickup truck, the object I want to add is something like rear spoiler. I can't create a proper volume to run the flow again. The spoiler is connected through an edge to the body of truck. If I change the connecting area and create a volume, I can't mesh it, as the volume mesh and face mesh doesn't coincide.
error1: Cannot create an ACIS body with multiple shells.
error2: Check the skews of face mesh. (If I create a volume successfully).
pendyala is offline   Reply With Quote
Old   July 24, 2013, 01:58
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
pictures, please
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 24, 2013, 17:05
ravi
In the following pictures, I considered a basic model for my primary evaluation. If you observe at the end there is small device like a spoiler attached which is the reason I couldn't mesh. Without adding that device, I got little acceptable results to.
Thank you.
Old   July 24, 2013, 17:07
ravi
After I add device and try to remesh, I get the error "check face mesh". Volume mesh failed due to improper face mesh.
Old   July 25, 2013, 01:56
-mAx-'s Avatar
Maxime Perelli
Has your spoiler a thickness, or did you build it as a baffle (surface)?
Old   July 25, 2013, 02:40
ravi
It has thickness. It is not exactly spoiler but a substitutional device we found through research. But very minimal thickness. Almost 2mm thickness .
Old   July 25, 2013, 02:47
-mAx-'s Avatar
Maxime Perelli
then you have to split your domain with each surface from your device.
Doing this, you should see the device as hollow (just like your truck).
But as your geomtry isn't so complex, maybe you could restart from "0": Merge truck and device volumes.
Substract this result from your outer box.
On the mesh side, you could have skewness problem because of this minimal thickness. You just need to apply a size function (thickness as source)
Old   July 26, 2013, 15:56
ravi
Basically, I tried to split my total domain into two so that I can have fine and coarse meshes. I am still uncertain of how the volume is simulated, if the inner volume is deleted from the outer domain.
3D wing + wind tunnel hexa structured meshing icemaniac178 ANSYS Meshing & Geometry 9 October 28, 2010 10:37
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Simulating a Göttingen type wind tunnel in FLUENT Chris FLUENT 3 December 4, 2006 18:33
