[ANSYS Meshing] Divergence in Transient solver |
July 16, 2013, 13:48 |
Rep Power: 14 |
Hello guys,
I've been trying to model a 2D vertical axis wind turbine using a transient solver. I had a tutorial which helped me a lot set up my problem and my code which defined the motion of the blade. The blade motion is defined by the equation of motion of of a four bar linkage. I can preview the mesh motion, which is what i need. The problem is that the solution diverges after only 10 iterations ! Do you reckon it's a problem from my code? (but the mesh motion is correct), or the mesh itself(which i highly suspect) or maybe the setup! (what is usually a key factor contributing to divergence in transient solvers) Many thanks |
July 17, 2013, 04:22 |
#2 | ||
Matthias Voß
Rep Power: 20 |
hi,
could be anything actually. Quote:
How do you know the mesh motion is correct? Remeshing? Morphing? matthias P.S.: try to solve ONLY for the mesh motion without any u,v,w,p,eps,... |
2d airfoil mesh, transient convergence |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 12:34 |
TUI Transient solver to Steady solver | mbell10 | FLUENT | 1 | February 2, 2011 09:53 |
Divergence detected AMG solver error | Rub Nawaz Khalid | FLUENT | 2 | August 14, 2010 12:01 |
reverse flow and divergence in AMG solver | MASOUD | FLUENT | 2 | April 2, 2010 09:48 |
Steadystate versus Transient solver | pda | OpenFOAM Running, Solving & CFD | 1 | July 11, 2007 09:36 |
