[ANSYS Meshing] Shadow region not created
Old   July 8, 2013, 03:28
Smile Shadow region not created
Karthik Ramaswamy
kartrmswy is on a distinguished road
Hello!
I need to analyse a 2D (axial) cross section of a dual pipe heat exchanger for a multiphase heat transfer problem.
I created the geometry on DM using sketches and surfaces - but I'm facing an issue with the walls: I need shadow regions created so that I can enable coupled heat transfer between the walls. I have explicitly specified multiple (fluid, solid, fluid) for the inner pipe region, pipe wall and the annulus.
Any way I can manually add a shadow region or get FLUENT to recognize that this wall is an interface between a solid and fluid?
Thanks!
kartrmswy is offline   Reply With Quote
Old   July 25, 2013, 06:07
Paritosh Vasava
vasava will become famous soon enough
Did you find a solution?
vasava is offline   Reply With Quote
ansys design modler, heat transfer, mesh, shadow
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
