[ICEM] Creating volume mesh with prism elements w/given triangulated surfaces in ICEM |
June 26, 2013, 17:04 |
Rep Power: 14 |
Hello All,
I am attempting to create a tetrahedral volume mesh with prism elements in the b.l. region from a given set of surfaces that bound the flow domain. The surfaces have been triangulated a priori. The option to generate the prism layer is greyed out in the volume meshing window (enclosed image). I was wondering whether there might be a technique to circumvent this problem. Vis-à-vis would another mesh generator like T-Grid or Gambit be a better option. Thanks |
June 27, 2013, 02:34 |
Answer
The problem is you don't have any "Geometry" menu in your "model tree".
The normal model tree is like this: |
July 3, 2013, 12:19 |
Rep Power: 20 |
when we import .msh file in ICEM(tetra mesh only), then how we can extract geometry from this file for applying prism layers? Can anybody tell me the detailed procedure please
Thanks Regards |
July 3, 2013, 12:42 |
Answer
As Far said:
Go to Edit menu and choose Mesh->Facets. Although using TGrid instead of ICEM for generating prism would be fun!
ICEM, CFX and Fluent expert |
July 3, 2013, 14:50 |
Rep Power: 20 |
thanks alot sajdad. I will ry it and will let you know
I only know a bit about tgrid but haven't tested it even once, do tgrid offer any advantage over ICEM for prisms generation? |
July 3, 2013, 15:31 |
TGrid vs. ICEM
Because if you have .msh file, you can directly import it in TGrid and with no other modification grow the prism.
And I think TGrid prism is comparable with ICEM.(personal experience)
July 31, 2013, 16:36 |
#8 | |
Rep Power: 14 |
Thanks for the suggestions. I have opted to import the surface mesh into T-Grid and generate the volume mesh with prism layers and a tetrahedral core. I am currently reading the T-Grid mesh back into ICEM to scale and setup the problem for Fluent. Regards |
icem cfd 13.0, surface to volume mesh |
ICEM - problems with prism mesh | João Lourenço | CFX | 2 | September 18, 2019 03:07 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Error when creating ICEM mesh output to CFX | Zoran | CFX | 4 | November 9, 2010 05:13 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
