June 25, 2013, 05:55 |
width in curve meshing
Hi mates,
In this thread http://www.cfd-online.com/Forums/ans...hing-icem.html, Simon has given a tip of making boundary layer around 2d object. He used width to make boundary layer. But what is "width"? I can only find "Tetra width", as seen in the picture. And also why he didn't use Number of Layers to make that boundary layer? http://i39.tinypic.com/awrpsz.jpg |
June 25, 2013, 09:47 |
#2 | |
sadjad.s: May be by setting tetra width simon was able to generate tetra mesh with some layers packed into boundary layer. he also said that prism in 2d failed due to the way geometry is assembled. Finally he shown the way to work with HEXA.
June 25, 2013, 10:19 |
Answer
Hi mate,
I think i got the answer via try and error. In 2d, there is no difference between "No. of Layers" and "Tetra width". As you see in the first picture, i used No. of layers of 10 to make boundary layer. It did it successfully. In the next try, i used Tetra width to make 8 layers: And if you determine both parameters, mesher will ignore Tetra width for 2d cases: |
June 25, 2013, 15:09 |
explanation
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
[ANSYS Meshing] ICEM Meshing :specified nodes along curve did not appear | syler3321 | ANSYS Meshing & Geometry | 3 | June 13, 2012 16:45 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 05:59 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
