Alberto Modrego
Rep Power: 13 ![]() |
Hello:
I am doing a research project and i would like to know which is the best mesh to use in a fluid, squared or triangle mesh. Thank you. |
Arthur Loginow
Rep Power: 14 ![]() |
Depend on the geometry that you are using
Alberto Modrego
It is a 2d simulation, it is a rectagle where the inlet is in the right and the outflow is in the left side, the top edge and the bottom edge are walls, which mesh do you recomend me to use?. Do you know if there is any document where i can see the diferences between the different kind of meshes?
Thank you. |
Maxime Perelli
Rep Power: 41 ![]() |
for a rectangle 2d, I think a structured mesh shouldn't be so complicated
In memory of my friend Hervé: CFD engineer & freerider ![]() |
Alberto Modrego
thank you -max-!!
difference between meshes |
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench | aarvay | ANSYS Meshing & Geometry | 11 | January 12, 2017 13:51 |
Hex and Tet meshes - simplefoam comparison | danvica | OpenFOAM Running, Solving & CFD | 10 | January 4, 2013 02:18 |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 08:06 |
Merging Meshes | Matteo Giacobello. | FLUENT | 1 | February 16, 2000 10:22 |
Large 3D tetrahedral meshes | Aldo Bonfiglioli | Main CFD Forum | 4 | August 27, 1999 04:33 |
