[DesignModeler] Macro / Script for automatic geometry import |
June 13, 2013, 06:10 |
Rep Power: 13 |
Hello everybody,
First I want to say that I searched in the forum for something similar but I found nothing, so I´m opening this topic. I´m performing an optimization in which the 3rd-party optimizer runs an external software for geometry generation that generates an .igs file, that, imported into DesignModeler, is the starting point for a parametric model, from where starts a complete CFD workflow. Here´s my problem: this .igs file is already present inside the DesignModeler tree, and, even if it is updated at every optimization step (by optimizer-->geometry generation software), it is not automatically updated in DM (think that even if the file is missing the geometry keeps working, I get only a message saying that the original file is missing...). So I tried to record a script from Workbench in File-->Scripting-->Start recording journal performing these actions: Opening DM from geometry block --> go to the Import feature in the tree --> RMB "Edit selections" --> Giving the path of .igs file --> Generate --> exit DM --> save file. But when I run this script workbench only opens DM and closes it, without doing all the import procedure. Does somebody have any kind of hint for me? Thanks in advance, best regards. |
June 14, 2013, 11:13 |
Simon Pereira
Rep Power: 47 |
I don't know what is wrong with DM (why it doesn't try to update), but generally speaking, IGES is a problem.
Each time you generate an IGES file, it generates new surface names without any consistency. It is a difficult starting point for any sort of parametric update. Just about anything else would be better.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
June 14, 2013, 12:24 |
Rep Power: 13 |
First thanks for the answer.
I even tried "manually" to change the imported file, change in WB a parameter (so he was obliged to refresh the DM component) and then I had a look in DM to see if the imported geometry was changed but it was still the old one. To change it, in the "Import" feature properties i found a feature "Refresh"(Yes/No) that if selected as Yes, gives me the chance to click on Generate and so the new geometry is loaded (please see screenshot attached). But this property has to be set manually every time, the simple Refresh of the DM component do not read the geometry file every time, that´s what I´m noticing. By the way, with some help I set up a Python script to command WB operations and a JavaScript script to make DM loading the file, and right now I´m performing some tests, but I have to wait for the results (finger crossed!). Concerning the IGES file, thanks for the hint, I will consider a change of format (will STEP be fine?). Thanks again! |
June 14, 2013, 15:13 |
Simon Pereira
Rep Power: 47 |
Step and IGES are similarly bad... ACIS, Parasolid, dwg and other formats are better because they persistently name their entities the same way between updates.
June 18, 2013, 08:59 |
Rep Power: 15 |
wasabi,
would you mind sharing the code for both WB and DM operations? I've reached an dead end and maybe you can get me out of there thanks, vigges |
June 20, 2013, 06:20 |
Rep Power: 13 |
August 12, 2013, 20:12 |
Rep Power: 13 |
I´m also facing problems importing geometries... I already generate parasolids, but it contains many bodies and when I change the geometry all of them become a separate part... I need to automaticaly form a new part with all the bodies in the geometry... how can I do it using script?
August 13, 2013, 04:45 |
Matthias Voß
Rep Power: 20 |
Regarding the IGES import:
You cannot use the "journaling" for the DM. Wb is Phython, DM is JScript. BUT: you can send JScript Commands to an DM-Container via the wb-journal. JScript isn´t supported but there is an overview in the documentation. I was facing a very similar problem with ICEM and a parametric geometry in an EXTRA dm container on the wb-schematic. I solved the not-upto-date-geometry-error by including the standalone geometry container in the appropriate simulation container (CFX, FLUENT, ANSYS, etc.) . Since the geometry AND the whole downstream action (meshing, solving, post) are stuffed in ONE update call everything worked out. There is smth. strange about different containers on the wb-schematic calling the update for containers downstream in the workflow and also vice versa. Reported it to the support ( they gave the idea mentioned above). Hope this helps.. Matthias Last edited by mvoss; August 13, 2013 at 07:52. |
August 13, 2013, 07:57 |
#9 |
Rep Power: 13 |
Thanks for your help!
I understand that I cannot use the "journaling" for the DM. But I can call a JScript from the wokbench journal... so what i'm trying to do is: WB journal: system1 = GetSystem(Name="FFF") geometry1 = system1.GetContainer(ComponentName="Geometry") geometry1.SetFile(FilePath="C:...........x_t") geometry1.Edit() script = open('C:...............js', 'r') geometry1.SendCommand(Command=script.read()) This code changes the .x_t geometry, opens the DM and runs the JScript file... but how would it be the JScript code to select all bodies in the geometry and form a single part? |
April 1, 2014, 20:05 |
#10 | |
Rep Power: 14 |
Hi ICS,
Anyway, what you can do is at the end of your "geometry.js" code, add this var X = agb.FormNewPartFromAllBodies(); X.name = "Y"; this will create single part from all the bodies. "Y" is th ename you want for the part which includes all bodies Hope it helps Cheers KAPI |
April 2, 2014, 07:40 |
#11 |
Rep Power: 13 |
Hi Kapi, thanks for your help.
I had already managed a solution, but I forgot to post here... this is how the code became: system1 = GetSystem(Name="FFF") geometry1 = system1.GetContainer(ComponentName="Geometry") geometry1.Edit() geometry1.SendCommand(Command="""ag.m.NewSession (1); ag.gui.CreateImport("C:/....x_t"); agb.regen(); ag.gui.PickFilter(5, true); ag.gui.SelectAll(); ag.m.FormBodyGroup();""") It opens the DM, create a new session, import the new geometry file, select all bodies and form a new group. In another thread I discussed a way to update the mesh and export the file: http://www.cfd-online.com/Forums/ans...esh-macro.html |
April 9, 2014, 01:27 |
#12 | |
Rep Power: 14 |
Hi ICS,
this is alone of the ways to make part from bodies in WBJN file. Quote:
I checked mesh macro link as well, its good, quiet similar to geometry. Keep up the good work! Cheers KAPI |
November 18, 2014, 13:05 |
#13 |
Mark
Rep Power: 15 |
Do you know a method of choosing only a few bodies as opposed to all?
November 24, 2014, 01:07 |
#14 |
Rep Power: 14 |
Hi Maw,
In your JS script you can either do Named selection of bodies and use them how you want or other option is to pick them from top to bottom, something like this Code:
body1 = ag.fm.Body(ag.fm.BodyCount-1); Hope this helps. Cheers Kapi |
October 27, 2015, 04:53 |
#15 |
Neal
Rep Power: 13 |
I also need to some how script the creation of a single part from many bodies. However the differences are that i am currently using a parameterized model in workbench that updates by running a journal file with new parameter values (that change the number of bodies by pattern operation).
How can i make a geometry script that will update the existing geometry in workbench and subsequently form the single part of all bodies? |
December 15, 2015, 00:40 |
#16 |
Rep Power: 14 |
Hi Neal,
I think you are after this function Code:
var Prt1 = agb.FormNewPartFromAllBodies(); Prt1.Name ="Part1"; Cheers KAPI |
August 29, 2016, 09:04 |
#17 | |
Aung Ko Latt
Rep Power: 10 |
Hello Everyone,
Just like Wasabi, I aslo have the same problem with you. I am stuck in this place. I tried to find solution but not find out till now. here is my workflow. In Design Modeller in my Ansys workbench workflow, I imported one geometry (in .igs file format) and it means that one geometry is already there and there were some additonal editing steps . In the other hand, I have a main Journal Script to command Workbench operations in WB GUI. Now I would like to replace that geometry with another geometry (in .igs file format) in Design Modeller. Is there any JScript command to replace and load another geometry and refresh the old additional editing steps in DesignModeller? I would like to put that JScript in main Journal Script. How can I link? I hope someone has an idea about this. Best Regards, Aung Ko Latt Quote:
August 31, 2016, 22:09 |
#18 | |
Rep Power: 14 |
as suggested by PSYMN
Secondly I am not sure if there is any function to replace your geometry file. You may have to delete the old file and import the new one. Kapi |
September 2, 2016, 12:26 |
Explode part/import multiple parts w/ NS
#19 |
Rep Power: 10 |
Hi all,
I'm trying to import a .prt geometry file as multiple parts. They are currently being imported as only 1 part with 3 bodies. I have identified several possible solutions - 1. I need to explode the imported geometry file in DM 2. Import multiple parts with named selections 3. Form a new part for each of the solid bodies I have not been able to find a command for 1. Using the import code: Code:
... newGeom = "D:/.....prt" geometry1.SetFile(FilePath=newGeom) geometry1.Edit() geometry1.SendCommand(Command="""ag.m.NewSession (1); ag.gui.CreateImport("D:\....1.prt"); agb.regen(); ag.gui.CreateImport("D:\....2.prt"); agb.regen(); ag.gui.CreateImport("D:\....3.prt"); agb.regen();""") I'm not sure how to use the Code:
body1 = ag.fm.Body(ag.fm.BodyCount-1); Any help is appreciated... This is the last step holding me back from automation. |
September 5, 2016, 00:54 |
#20 | |
Rep Power: 14 |
you will not be able to "explode" in DM
bring in each geometry separately if u wish! care to explain more what u want? Quote:
Once created you can call the bodies and use functions on them. What functions do u want to use? |
[ICEM] How to Import a DWG Geometry to ICEM? | qzsky | ANSYS Meshing & Geometry | 6 | June 11, 2013 07:43 |
[DesignModeler] problem with import geometry from catia | pavilion | ANSYS Meshing & Geometry | 1 | November 23, 2012 11:45 |
[ICEM] Problem in geometry creation by script | lavoz | ANSYS Meshing & Geometry | 4 | March 12, 2010 11:56 |
import catia geometry in icem v10 | anorky | Main CFD Forum | 4 | December 26, 2009 02:15 |
creating geometry using "Script files" in ICEMCFD | jaber | Main CFD Forum | 1 | November 11, 2007 10:28 |
