[ICEM] Error 2D mesh - Separate curves seen as one when associating
Old   June 11, 2013, 06:52
Default Error 2D mesh - Separate curves seen as one when associating
Bayard Morales
bbmorales is on a distinguished road
Hello there.
I have been dealing with the same problem over and over in ICEM 14.0, maybe you can help me.
I am creating a simple 2D mesh, following the procedure below:
1) create points
2) create curves from points
3) create parts from curves
4) create planar 2D block
5) associate edges to curves
6) define pre-mesh params
7) convert to unstructured mesh
8) output to FLUENT
What happens is when I read the mesh in FLUENT, the boundary conditions (related to the parts) can't be seen.
Going back to ICEM, I noticed that when I check the Info of each part, the missing parts contains no elements - as if the was no edge association to them.
I tried to redo the edge association to the curves and then I have found that when I try to select the a single curve (related to a part), I can only select all curves at once.
The only solution I've found so far is to deleted all the geometry and build it again.
Any idea? Am I doing something blatantly wrong?
Cheers
bbmorales is offline   Reply With Quote
Old   June 11, 2013, 07:13
Javi
FJSJ is on a distinguished road
Hi Bayard,
Once you have done the association, if you want to select only a part of one curve you need to Ungroup the curve. So, for do that, you have to click in Blocking -> Group/Ungroup Curves -> Action "Ungroup Curves" -> Select curve or curves.
FJSJ is offline   Reply With Quote
Old   June 11, 2013, 12:35
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
http://www.cfd-online.com/Forums/ans...em-fluent.html
Far is offline   Reply With Quote
Old   June 11, 2013, 12:56
Bayard Morales
[SOLVED]
Far and FJSJ
Thanks for your prompt answer!
The problem was that the curves were grouped - as pointed out by FJSJ.
Ungrouping the curves solved the issue.
Best regards!
blocks, mesh
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Mesh Mignard FLUENT 2 March 22, 2000 06:12
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
