[ICEM] Unable to load the zone from mesh file in Fluent
Old   June 8, 2013, 11:04
Default Unable to load the zone from mesh file in Fluent
Rohit Bhaya
Rohit Bhaya is on a distinguished road
Hello everyone,
I am new to ICEM CFD and needed help regarding my problem.
I have a simple geometry of a cuboid with a cylinderical pipe inside it. The geometry is attached.
I was able to generate the block structure, varied the node variation and form a pre-mesh of the grid. The pre-mesh diagram is also attached.
I saved the unstructured mesh, set my boundary conditions (assigining separate zone ID for each surface) and exported the mesh in the format *.msh. Upon loading it in Fluent, it does not show the zone of the cylindrical pipe surface. I even tried set the boundary condition of the pipe to wall, but the same problem occured.
I think the problem is in the unstructured mesh (pic2), as it does not show the surface mesh of the inner pipe. I tried to look for the option to pre-mesh it by parts but wasn't able to find it.
I request you to please help me in this regard. I tried searching the forum for the problem, but couldn't find any solution.
Thanks
Rohit
Rohit Bhaya is offline   Reply With Quote
icem cfd 13.0
which tutorial can find that include Riemann boundary condition? immortality OpenFOAM Running, Solving & CFD 12 May 3, 2013 19:21
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 09:42
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 16:52
