June 5, 2013, 10:34 |
problem volume mesh with STL
hadrien calmet
Rep Power: 14 |
Hi everybody
I try to mesh the volume around a stl, it is a car. -first I was thinking that with a delauney was ok, creating a box around the stl and meshing the box and adding the stl mesh inside. But it don't work, I can let my workstation running 2 or 3 days but ansys not succeed to fill the volume. -second using the tutorial of how to import stl (aorte), trim/seg surface, extract curves..... and after curvature/proximity and octree mesh (without forget "close gap") but the result is horrible and with lot of holes. -third with the 2D mesh method suitable for this case, shrinkwrap, but it don't work neither I post 2 pictures to show that exist gaps in the original stl, but I almost sure that I am not the only one working with this kind of input with smalls gaps and holes. any idea or suggestion are welcome thank you |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[ICEM] volume mesh leaking out of the surface, in a multi zone problem | premchandpendota | ANSYS Meshing & Geometry | 6 | July 31, 2012 01:36 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
