[GAMBIT] problem in 3d mesh with gambit
Old   June 4, 2013, 13:56
Default problem in 3d mesh with gambit
mohsen kh
m5m5kh is on a distinguished road
Hi buddies
I have some problems with meshing a volume in gambit.
I attach my file pictures, I want to mesh the inner square but the 4 faces of this sqaure have holes.
I wonder if I can mesh this squre using MAP mesh to have a structured mesh or not.
Thanks and look forward for your helps
Mohsen
http://tinypic.com/view.php?pic=2v83lfr&s=5
http://i43.tinypic.com/2wnv1tu.png
m5m5kh is offline   Reply With Quote
Old   June 5, 2013, 02:58
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
2 questions:
*what represent green entitites? (or what do you want to compute)
*how many volumes do you have (geometry/volume/delete pick and check how many volumes do you have)
the cyan color indicates you don't have any volume attached to this (cyan) surfaces
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 5, 2013, 05:06
mohsen kh
Originally Posted by -mAx- View Post
2 questions:
Hi -mAx-
I want to model a furnace with 72 eliptic holes around it. I know there are no volumes attached to this volumes I will try to complete other volumes and then ask for your help. thanks for your reply
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[GAMBIT] Problem with mesh in Gambit giuseppemerlini ANSYS Meshing & Geometry 12 November 10, 2014 02:04
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
Problem for making mesh in GAMBIT chlim FLUENT 0 July 8, 2005 19:23
