[ICEM] Need a help for merging hexa/tetra mesh..
Old   May 26, 2013, 00:11
Default Need a help for merging hexa/tetra mesh..
Andrew Kang
earth07 is on a distinguished road
Hello, I have an issue with merging hexa/tetra mesh..
What I'm trying to do is to merge tera mesh with hexa mesh but interface of geometry for hexa mesh is larger than that for tetra mesh.
I've been following 'Hybrid tube' in the tutorial, but it seems I don't know
how to merge them when the two interface areas are different.
I tried to match the area of interface and try to match the mesh
but it didn't work.
If I use 'merging node with tolerance', it just ruin hexa mesh nodes distribution. I only want tetra mesh to be conformed to hexa mesh..
I uploaded the simple geometry for this case on below link..
Do any of you know how to tackle this problem, please let me know..
I will really appreciate your help..
http://www.2shared.com/file/i4A97jpE/test3.html
earth07 is offline   Reply With Quote
Old   May 26, 2013, 14:48
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
you have inter1 and inter2... you need just one inter, it should contain both the structured and unstructured. you will convert your structured mesh to unstructured (use merge instead of replace) then merge using that only inter under the edit mesh tab... let me know if this works for you... it should work
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   May 26, 2013, 18:00
Javi
FJSJ is on a distinguished road
Hi Andrew & Diamondx,
I“ve read your doubt. I“m trying the whole weekend to get something similar "a priori" easier than this but I can“t. For that reason, when I read this post I tried to do this example.
Here the link with the project.
https://www.dropbox.com/s/4xa3eex83m...rgeproject.rar
I did exactly the same geometry and I did the same approach. As diamondx told you, you need only 1 interface instead of two. Once you have the hexa mesh and tetra mesh you only need to go to Merge Nodes, Merge Meshes, Merge Surface Mesh Part and click over your interface and et voilą!
I hope this was your doubt!
FJSJ is offline   Reply With Quote
Old   May 28, 2013, 02:48
Andrew Kang
Thanks a lot. it worked for the small geometry!
merge hexa/tetra
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre powpow CFX 3 December 20, 2012 10:14
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 07:30
basic of mesh refinement arya CFX 4 June 19, 2007 13:21
