June 2, 2014, 06:43 |
#22 |
Germany
Rep Power: 12 |
i send you in 10 min.
June 2, 2014, 07:00 |
#23 |
Germany
Rep Power: 12 |
Hi Far,
i meshed it as you can see it, it needed a lot of times to mesh it. After 2 weeks i could do it because the geometry is very complex. As i told you, the problem is fluent, if i load it in fluent i recieved nagative cell volume and other problems that i dont now why the problems exist after mesh checking in icem. |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
[General] extract Ids of point subset from a give triangular surface | nacaairfoil | ParaView | 1 | September 18, 2012 13:19 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 13:11 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 02:10 |
Normal - Helical Surface | m. malik | Main CFD Forum | 3 | February 3, 2006 13:56 |
