[ICEM] Hole near the boundary edges for 3D mesh
Old   May 22, 2013, 07:05
Default Hole near the boundary edges for 3D mesh
Ftab
ftab is on a distinguished road
Hi all,
I am trying to mesh a quite complicated geometry part by part.
The problem is that when I am trying to mesh a very simple parts, it is detecting holes in the boundary and making a very weird mesh. Check the image.
What I should do to avoid it?
Thanks
ftab is offline   Reply With Quote
Old   May 22, 2013, 12:04
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
did you build topology ?? give a smaller size ...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   May 22, 2013, 12:07
Ftab
Yes, I have build the topology!
Smaller than this will make the volume mesh go higher than 100 G cells.
Building the topology, I put all the curves and points in a separate part, GEOM.
Old   May 22, 2013, 12:43
Andreas
a.ob is on a distinguished road
Have you tried lowering the tolerances?
a.ob is offline   Reply With Quote
Old   May 22, 2013, 12:50
diamondx's Avatar
Ghazlani M. Ali
share your project if you can via dropbox ...
Regards,
Ali
hole, icem cfd, stl mesh
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
