Emilio Sessa
Rep Power: 0 ![]() |
Hello everyboby,
I have a problem to submit that's making me waste a lot of time. I have to mesh a simple 3D geometry costing of two solids: a brick with a cylinder inside that's tangent to its four sides. However when i use ICEM in interactive mode override, I can't manage well geometry. When trying to associate the two circles (curves) to the matching edges it tells me that no edges has been selected for association. Is it not for i should split circles or the lateral surface of the cylinder into two halves? Please reply me! Emilio |
association, circles, icem 3d, split, split a surface |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
2D geometry to 3D geometry | Sgonzalezg | ANSYS Meshing & Geometry | 11 | April 8, 2011 11:02 |
[snappyHexMesh] Trouble with stl file: surface not closed (snappyHexMesh) | sfalsharif | OpenFOAM Meshing & Mesh Conversion | 3 | April 3, 2011 05:53 |
[GAMBIT] Trouble meshing complex VOF geometry | RPJones | ANSYS Meshing & Geometry | 2 | February 14, 2011 18:54 |
[snappyHexMesh] stl geometry trouble | vaina74 | OpenFOAM Meshing & Mesh Conversion | 1 | December 7, 2010 05:11 |
