[ANSYS Meshing] overlapping heat exchanger cores- as in ansys user guide
Old   May 16, 2013, 00:59
Question overlapping heat exchanger cores- as in ansys user guide
Lagunesvary
chinna is on a distinguished road
Hai, thanks for your time... im using ansys fluent 14.0 to simulate heat exchanger and wanted to use dual cell model..
According to the ansys user manual..
If the mesh file does not already contain overlapping heat exchanger cores for primary and auxiliary fluids, then you must create a duplicate of the zone that represents the core using the following text command:
mesh → modify-zones → copy-move-cell-zone
You will then be prompted to enter the ID of the zone you want to copy, and either the distance for translation in each of the axes or the rotational angle, origin, and axis.
& when i try
modify-zones/: Enter the modify zones menu.
?: Enable help mode. Type "q" to return to command mode
invalid command [copy-move-cell-zone]
/mesh> 13
invalid command [13]
i dont know where`s my mistake. i really don`t have any idea,how to respond the command. can anyone please help me with this...??
is there any other ways to create overlapping zone??
chinna is offline   Reply With Quote
Old   March 14, 2014, 05:04
Default mesh commands
jacek is on a distinguished road
it work for me.
I have another problem with, dual cell. I can't initialize solution as I get something like this: "Unassigned interface zone detected for interface 34". In fact I get several such warnings. I don't know what to do. Mesh Interface tool allows only to connect pairs of interfaces. The rest is still on and is blocking Solution Initilization.
What shell I do?
jacek is offline   Reply With Quote
Double pipe heat exchanger mohcin FLUENT 21 June 18, 2016 15:19
OVERLAPPING ZONES in HEAT EXCHANGER chinna FLUENT 0 April 18, 2013 06:42
how to modeling heat by fluent and ansys? njiit FLUENT 0 December 9, 2009 01:39
Tube in Tube heat exchanger( But I got error) Young CFX 2 September 26, 2008 02:35
Heat Exchanger...TWO Walid CFX 2 July 11, 2005 20:04
