[GAMBIT] Problem in meshing a pipe within a cylinder
Old   May 14, 2013, 06:13
Default Problem in meshing a pipe within a cylinder
Tony
l14766 is on a distinguished road
I am new in Gambit and I did the model of my reactor (UASB),
There is a cylinder with an influent pipe on the bottom and an effluent pipe on the up side, the funnel is used to collect gas produced in the reactor (little gas was produced so it is neglected).
I create a 2-D model in Gambit with two separated faces, while seems that the funnel has little influence on the fluid, should any opration be done to connect the two separated faces? What should be the suitable boundary conditions for the pipes?
Thanks,
Tony
l14766 is offline   Reply With Quote
Old   May 14, 2013, 08:52
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
what is this body with trianle basis?
Looks like a spool entering in your cylinder.
If it is a solid body (no flowfield inside the spool), then you have to go back in Gambit and you need to split your cylinder with the spool. Finally the spool should appear as an hollow, which means no flowfield expected in this area.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 14, 2013, 09:26
Tony
Thanks for your reply.
It is an inverted funnel (just like a pipe) and the fluid can flow into it. Should I split the cylinder with the funnel and then connect them?
Old   May 14, 2013, 09:28
-mAx-'s Avatar
Maxime Perelli
where can the flow enter in this funnel? Are there openings?
Do you have a cross scetion from cad or anything for better understanding?
Old   May 14, 2013, 09:57
Tony
The funnel is a hollow cone with large opening on the bottom and a narrow tube at the apex, which is used to collect the gas produced, as the opening is lower than the effluent pipe (water level), so the flow can also enter, but probably it will not outflow through the narrow tube at the apex
http://132.68.226.240/english/pdf/Pr...al_Green/2.pdf picture 1 (a) is a sample UASB reactor
Old   May 14, 2013, 10:06
Tony
These are more visualized exsamples of UASB reactor
Old   May 14, 2013, 10:43
-mAx-'s Avatar
Maxime Perelli
ok
post a picture of your gambit geometry (without mesh) and locate your BC, especially on your cone.
The question is: is your cone splitted from the cylinder or is it totally free (not connected).
The cone should split the cylinder, BUT, you need to redefine all the cone edges as wall (except the bottom one). Thus split operation generates internal (or interior) entities for giving the possibility to the fluid for flowing through.
Old   May 14, 2013, 18:24
Tony
ok
Thanks, seems that it works
[GAMBIT] Meshing a pipe vedravi ANSYS Meshing & Geometry 1 March 25, 2010 14:19
[Commercial meshers] problem meshing two interacting volumes banerji OpenFOAM Meshing & Mesh Conversion 0 December 14, 2009 16:59
[ICEM] Problem with boundary layers for cylinder in channel nik ANSYS Meshing & Geometry 0 October 27, 2009 07:01
Meshing problem akr FLUENT 2 February 3, 2008 21:22
Problem meshing very thin pipe B. Hemmen FLUENT 2 May 16, 2006 09:29
