April 25, 2013, 10:37 |
#21 |
Robert
Rep Power: 13 |
AT LAST!!! This was a difficult birth like we say here.
I almost got the working steps from the pictures, but this took some time. The explanations were helpful. I still don't get the difference, but thats ok. I will repeat that for different geometries and then i hopefully understand it. Thanks for the kind help. |
April 25, 2013, 10:45 |
#22 |
AB
Rep Power: 22 |
From what I understood, your mistake was to associate the o-grid you created in block 1 and 3 and associated the edges of those o-grids with the curves of the small tube. Because before that, you already associated the edges of the o-grid of bloc2 with the curves of the small tube.
So you have 2 edges for 1 curve, which is wrong. It created a 0-volume at the junction of the tubes. I hope my explanations were clear ... |
April 26, 2013, 04:18 |
#23 |
Robert
Rep Power: 13 |
OK, i think i understand it now.
Thanks for the help! |
April 26, 2013, 04:32 |
#24 | |
June 10, 2014, 19:13 |
#25 |
Kartik
Rep Power: 12 |
hi there, im trying to mesh a geometry very similar to this, the only difference being that the central pipe section is very short and behaves like an orifice. The steps are very clear in this post but could someone please further clarify step 6 please.
thanks in advance |
January 25, 2015, 19:25 |
#26 |
Tanjina Afrin
Rep Power: 13 |
Hello, is it possible to do this grid on workbench mesher?
Regards, Tanjina |
January 27, 2015, 16:49 |
#27 |
Javi
Rep Power: 16 |
Hi Tanjina,
I think you could try to do it but you need to split your geometry to get parts as O-grid topology approach. Take a look at this thread: [ANSYS Meshing] Problem with structured meshing pipe elbow |
January 29, 2015, 17:10 |
#28 |
Tanjina Afrin
Rep Power: 13 |
Thanks ! I am trying..... but it seems I have some problem.
change / changing, diameter, pipe |
[ICEM] Simple pipe meshing - problems with y+ in CFX | Keizers | ANSYS Meshing & Geometry | 23 | January 15, 2015 08:00 |
[GAMBIT] GAMBIT Meshing of Pipe with Holes Perpendiculer to Flow Stream | rocketman1151 | ANSYS Meshing & Geometry | 7 | November 30, 2011 02:39 |
[GAMBIT] Meshing a pipe | vedravi | ANSYS Meshing & Geometry | 1 | March 25, 2010 13:19 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
